I have adapted udp sock example in docs to ipv4 version.
However i am getting " Error creating UDP sock " problem. I could not figure it out why.
This is the cliend side code. In docs example i have successfuly run it in ipv6 and in java i received messages at server side.
Hardware: Board=esp8266-esp-12x
Thanks for your help
GNRC does not support IPv4. Check out lwIP [1] as an alternative that supports that protocol.
Martine
[1] https://github.com/RIOT-OS/RIOT/tree/master/tests/lwip
You are a time saver for me. Thanks for your answer. It is big help to me.
Martine Lenders <mail@martine-lenders.eu>, 14 Tem 2019 Paz, 15:27 tarihinde şunu yazdı:
