I'm trying to flash the iot-lab_M3 board and constantly fail on:
Error: no device found
Error: unable to open ftdi device with vid 0403, pid 6010, description 'FITECO M3' and serial '*'
I've compiled and installed OpenOCD (0.9.0-dev-00186-g30203b3) which perfectly works with the SAMR21-xpro board.
I use `make BOARD=iot-lab_M3 flash` to try flashing.
I also tried to invoke the flash script manually:
`sudo BOARD=iot-lab_M3 ./flash.sh hello-world.hex`
with the same result.
Has anyone a hint for me what I'm doing wrong.
Thanks and best regards,
Martin
Hi Martin,
I have a stupid question at this point: did you set PORT correctly?Cheers
Emmanuel
Hi Martin!
Sorry, my bad.
I was told that on the newer nodes they changed the device description from
"FITECO M3" to simply "M3" (or "A8-M3" for the nodes connected over an A8).
So, changing this in boards/iot-lab_M3/dist/iot-lab_M3_jtag.cfg should help.
Oleg
Hi again!
Or try with https://github.com/RIOT-OS/RIOT/pull/1996 - apparently `dev_desc`
isn't really necessary.
Oleg
Hi Oleg,
thx for the reply and the PR, its better now, but now fails with:
Info : clock speed 1000 kHz
Info : JTAG tap: stm32f1x.cpu tap/device found: 0x3ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x3)
Info : JTAG tap: stm32f1x.bs tap/device found: 0x06414041 (mfg: 0x020, part: 0x6414, ver: 0x0)
Error: Failed to read memory at 0x00000000
Error: JTAG-DP OVERRUN - check clock, memaccess, or reduce jtag speed
Error: MEM_AP_CSW 0x23000042, MEM_AP_TAR 0xe000edf0
Martin
Hi Martin!
0x6414, ver: 0x0)
Indeed, I had a similar problem. Reverting to the old configuration (git
revert e455664cfc75f9b5dfb3a8f04349dadac6a85c7d) helped. After flashing once
with the legacy configuration, it worked again with the current settings. I
have no idea why. But maybe we should revert to the legacy settings for now.
Oleg
Hi Oleg,
sorry for bothering.
I reverted, but still no luck
invoking `make BOARD=iot-lab_M3 flash` results in
DEPRECATED! use 'adapter_khz' not 'jtag_khz'
adapter speed: 1000 kHz
Error: The specified debug interface was not found (ft2232)
I tried to change iot-lab_M3_jtag.cfg:5 to FT2232H -> same result.
using ftdi resulted in `invalid command name "ft2232_layout"` for the next line
dmesg states with the connected device:
[19263.378582] usb 2-1.2: new high-speed USB device number 15 using ehci-pci
[19263.473542] usb 2-1.2: New USB device found, idVendor=0403, idProduct=6010
[19263.473550] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[19263.473555] usb 2-1.2: Product: M3
[19263.473559] usb 2-1.2: Manufacturer: IoT-LAB
[19263.474569] ftdi_sio 2-1.2:1.0: FTDI USB Serial Device converter detected
[19263.474637] usb 2-1.2: Detected FT2232H
[19263.474643] usb 2-1.2: Number of endpoints 2
[19263.474648] usb 2-1.2: Endpoint 1 MaxPacketSize 512
[19263.474654] usb 2-1.2: Endpoint 2 MaxPacketSize 512
[19263.474659] usb 2-1.2: Setting MaxPacketSize 512
[19263.474961] usb 2-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
[19263.475803] ftdi_sio 2-1.2:1.1: FTDI USB Serial Device converter detected
[19263.475874] usb 2-1.2: Detected FT2232H
[19263.475880] usb 2-1.2: Number of endpoints 2
[19263.475885] usb 2-1.2: Endpoint 1 MaxPacketSize 512
[19263.475889] usb 2-1.2: Endpoint 2 MaxPacketSize 512
[19263.475893] usb 2-1.2: Setting MaxPacketSize 512
[19263.476231] usb 2-1.2: FTDI USB Serial Device converter now attached to ttyUSB1
Martin
Hi Martin!
No problem.
If you have built OpenOCD yourself, make sure to run the configure script with
--enable-legacy-ft2232_ftd2xx
to enable the legacy interface (IIRC). Thomas might correct me if I'm wrong.
Oleg
Hi Oleg,
tried it, but still no luck.
I also tried it together with @PeterKietzmann on a different linux distribution but all the same results for all steps.
Martin
Hi Martin,
below the configuration options I use to build for OS X
./configure —disable-dependency-tracking —prefix=<your/desired/path> —enable-dummy —enable-buspirate —enable-jtag_vpi —enable-remote-bitbang —enable-usb_blaster_libftdi —enable-presto_libftdi —enable-openjtag_ftdi —enable-legacy-ft2232_libftdi
Let me know if this helps, I’d update the wiki accordingly.
Best, Thomas
Hi Thomas,
it worked!
I had to install libftdi-dev
first. ./configure complained checking for LIBFTDI... no
using your provided options.
I used:
./configure --disable-dependency-tracking --prefix=<my/desired/path> --enable-dummy --enable-buspirate --enable-jtag_vpi --enable-remote-bitbang --enable-usb_blaster_libftdi --enable-presto_libftdi --enable-openjtag_ftdi --enable-legacy-ft2232_libftdi
as you provided.
This didn’t helped alone.
I applied git revert e455664cfc75f9b5dfb3a8f04349dadac6a85c7d
as Oleg stated,
and
I removed the ftdi_device_desc
form iot-lab_M3_jtag.cfg
and viola, it flashes.
Now the spooky part (confirms Oleg’s observation):
After flashing the device once I reverted the revert, and can flash with the current iot-lab_M3_jtag.cfg
configuration (still have to remove ftdi_device_desc
Thx Thomas, thx Oleg.
Martin
