Yes, you will get 6LowPAN there because the network interface is declared as 6LowPAN compatible (IEEE 802.15.4).
Thanks, @jia200x
I’ll configure timeout and give you a feedback.
If I use 6LowPAN already, how should I understand it?
gnrc_networking and gnrc_border_router works as in examples in readme’s. As I know, 6LowPAN can compress header which makes a packet less, can communicate by short addresses. All is not clear for me.
I’m sorry if I trouble you.
Hi @HoCoK
If you enable debug on sys/net/gnrc/network_layer/sixlowpan/gnrc_sixlowpan.c, you should be able to see 6LowPAN debug messages. That indicates that 6LowPAN is running.
6LowPAN defines header compression and packet fragmentation, so it allows transmitting full IPv6 frames with low MTU link-layers (e.g IEEE 802.15.4). In GNRC this is transparent to the upper layer (IPv6, UDP, CoAP), therefore you don’t need to configure anything actively (of course there are tweaks you can do, but they are not required to run 6LowPAN out of the box).
Communication using short addresses it’s not related to 6LowPAN, as this is a IEEE 802.15.4 feature. I’m not sure though, if the GNRC network interface maps 6LowPAN frames to the short address. That could be addressed if it’s not the case.
You can try to ping with a packet size larger than the IEEE 802.15.4 MTU (104 bytes payload). E.g try this:
ping <IP address> -i 10000 -s 300
That would confirm 6LowPAN is running.
Cheers.
Ok, @jia200x
I think I got it.
Ping
[17:38:13:597] > ping fe80::a4de:1264:dac5:a42b -i 10000 -s 300␍␊
[17:38:47:192] 308 bytes from fe80::a4de:1264:dac5:a42b%7: icmp_seq=0 ttl=64 rssi=60 dBm time=6380.098 ms␊
[17:38:57:177] 308 bytes from fe80::a4de:1264:dac5:a42b%7: icmp_seq=1 ttl=64 rssi=60 dBm time=6364.780 ms␊
[17:39:07:188] 308 bytes from fe80::a4de:1264:dac5:a42b%7: icmp_seq=2 ttl=64 rssi=60 dBm time=6371.498 ms␊
[17:39:07:188] ␊
[17:39:07:188] --- fe80::a4de:1264:dac5:a42b PING statistics ---␊
[17:39:07:210] 3 packets transmitted, 3 packets received, 0% packet loss␊
[17:39:07:210] round-trip min/avg/max = 6364.780/6372.125/6380.098 ms␊
Thank you for your support! When I get some extra boards, I’ll try to create a cluster-tree network.
Hi, @jia200x
While I’m waiting extra boards, I found some issues with CSMA-CA and frame retransmissions in my implementation:
ACK_TIMEOUT doesn’t changes a quality of transmission. Packets are duplicate about 4 times, “ping” has a huge latency. Only -ack_req helps.
CSMA-CA doesn’t work. As I think, CSMA-CA should call a CCA before transmission. If CCA says that link is clear, module waits a bit and transmission begins. But I have not seen, where submac runs a CCA function (ieee802154_radio_cca), except ieee802154_hal test.
gnrc_netif_ieee802154.c
#ifdef MODULE_GNRC_MAC
if (netif->mac.mac_info & GNRC_NETIF_MAC_INFO_CSMA_ENABLED) {
res = csma_sender_csma_ca_send(dev, &iolist_header, &netif->mac.csma_conf);
This function is never reached from submac…
I will be glad to see your suggestions.
Hi @HoCoK
This occurs when the MAC does not receive an ACK frame. In such case, the SubMAC will perform retransmission. By default, the SubMAC will try to send up to 4 times if it doesn’t receive ACKs. That’s why you see 4 packets.
Did you implement the ACK reply in the driver? The Radio HAL documentation states:
The transceiver or driver MUST handle the ACK reply if the Ack Request bit is set in the received frame and promiscuous mode is disabled.
This means, the driver has to reply with an ACK frame if the ACK Request bit is set. See e.g RIOT/cpu/nrf52/radio/nrf802154/nrf802154_radio.c at master · RIOT-OS/RIOT · GitHub to see how this is implemented in the NRF52840.
- It is a bit misleading, but
MODULE_GNRC_MAChas nothing to do with the SubMAC. This is just a 6 years old module the enable other MAC protocols in GNRC (namely lwmac and gomach). When you use the SubMAC with GNRC Netif, the dependency tree looks like:
gnrc_netif_ieee802154 => netdev_ieee802154_submac =>ieee802154_submac => ieee802154_hal_t
In words, GNRC Netif only “speaks” netdev (which will eventually change after the migration phase). Therefore, we developed a netdev_ieee802154_submac module that implements the netdev interface on top of the SubMAC.
Regarding CCA, the current SubMAC implementation assumes the radio always performs CCA if CSMA/CA retries are not disabled:
- @brief Set the CSMA-CA parameters.
- @pre the device is on
- @param[in] dev IEEE802.15.4 device descriptor
- @param[in] bd parameters of the exponential backoff. If NULL, the
parameters are not altered.- @param[in] retries number of CSMA-CA retries. If @p retries < 0,
retransmissions with CSMA-CA MUST be disabled.If @p retries == 0, the @refieee802154_radio_request_transmit function isequivalent to CCA send.- @return 0 on success
- @return -EINVAL if the settings are not supported.
- @return negative errno on error */ int (*set_csma_params)(ieee802154_dev_t *dev, const ieee802154_csma_be_t *bd, int8_t retries);
Therefore, you have to implement it in the driver. You can check the NRF52840 implementation too. Note that there’s no real way to do CCA in LoRa as RSSI cannot detect frames below the noise floor. But you could use CAD to try to detect a frame.
Hello @jia200x
I continue to make an implementation radio hal for lora and again met with some issues.
Now I try to implement ACK reply. I run ieee802154_hal test and what I receive:
Transmiter
[16:22:32:810] main(): This is RIOT! (Version: 28a8b)␊
[16:22:32:810] Trying to register sx126x.␊
[16:22:32:810] Success␊
[16:22:32:827] Initialization successful - starting the shell now␊
[16:22:32:827] > txtsnd DE:EE:68:50:08:4E:84:05 10 ackreq␍␊
[16:22:40:742] Transmission succeeded␊
[16:22:40:742] ␊
[16:22:40:742] ␊
[16:22:40:742] > Size = 3␊
[16:22:40:752] Received valid ACK with sqn 0␊
[16:22:40:763] 00000000 02 00 00 ...␊
[16:22:40:763] LQI: 255, RSSI: 208␊
[16:22:40:763] ␊
[16:22:42:957] txtsnd DE:EE:68:50:08:4E:84:05 10 ackreq␍␊
[16:22:42:979] Transmission succeeded␊
[16:22:42:979] ␊
[16:22:42:979] ␊
[16:22:42:979] > Size = 3␊
[16:22:42:989] Received valid ACK with sqn 1␊
[16:22:43:020] 00000000 02 00 01 ...␊
[16:22:43:020] LQI: 255, RSSI: 208␊
[16:22:43:020] ␊
[16:25:19:684] test_states␍␊
[16:25:19:694] Testing TX<->RX transition time: 153 us (PASS)␊
[16:25:19:694] Testing RX<->TX transition time81 us (PASS)␊
[16:25:19:694] >
Receiver
[16:22:30:697] main(): This is RIOT! (Version: 28a8b)␊
[16:22:30:697] Trying to register sx126x.␊
[16:22:30:697] Success␊
[16:22:30:713] Initialization successful - starting the shell now␊
[16:22:30:713] > Size = 31␊
[16:22:40:751] Frame received:␊
[16:22:40:759] 00000000 61 DC 00 23 00 05 84 4E 08 50 68 EE DE 2B B4 C5 a..#...N.Ph..+..␊
[16:22:40:768] 00000010 DA 64 12 DE A6 4C 6F 72 65 6D 20 69 70 73 75 .d...Lorem ipsu␊
[16:22:40:768] LQI: 255, RSSI: 208␊
[16:22:40:768] ␊
[16:22:42:987] Size = 31␊
[16:22:42:987] Frame received:␊
[16:22:42:995] 00000000 61 DC 01 23 00 05 84 4E 08 50 68 EE DE 2B B4 C5 a..#...N.Ph..+..␊
[16:22:43:005] 00000010 DA 64 12 DE A6 4C 6F 72 65 6D 20 69 70 73 75 .d...Lorem ipsu␊
[16:22:43:005] LQI: 255, RSSI: 208␊
[16:22:43:005] ␊
As I understand it, all works fine. I transmit a frame with ack_req bit and I get back an ack frame.
But I cannot see an ack_frame in ieee802154_submac test. The rx_done handler doesn’t fire after ack reception:
submac transmiter
[16:51:09:120] > txtsnd DE:EE:68:50:08:4E:84:05 80␍␊
[16:51:11:362] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:362] [sx126x] netdev: send: wrote data to payload buffer.␊
[16:51:11:372] [sx126x] netdev: send: wrote data to payload buffer.␊
[16:51:11:372] [sx126x] writing (size: 101).␊
[16:51:11:372] > [sx126x] netdev: set STATE_TX␊
[16:51:11:428] [sx126x] netdev: SX126X_IRQ_TX_DONE␊
[16:51:11:428] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:428] [sx126x] netdev: set STATE_RX␊
[16:51:11:428] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:432] [sx126x] netdev: SX126X_IRQ_PREAMBLE_DETECTED␊
[16:51:11:436] [sx126x] netdev: SX126X_IRQ_HEADER_VALID␊
[16:51:11:439] [sx126x] netdev: SX126X_IRQ_RX_DONE␊
[16:51:11:443] [sx126x] Received ACK.␊
[16:51:11:443] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:448] [sx126x] netdev: read received data.␊
[16:51:11:451] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:456] [sx126x] netdev: set STATE_TX␊
[16:51:11:509] [sx126x] netdev: SX126X_IRQ_TX_DONE␊
[16:51:11:509] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:509] [sx126x] netdev: set STATE_RX␊
[16:51:11:514] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:528] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:530] [sx126x] netdev: set STATE_TX␊
[16:51:11:581] [sx126x] netdev: SX126X_IRQ_TX_DONE␊
[16:51:11:581] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:581] [sx126x] netdev: set STATE_RX␊
[16:51:11:586] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:598] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:602] [sx126x] netdev: set STATE_TX␊
[16:51:11:655] [sx126x] netdev: SX126X_IRQ_TX_DONE␊
[16:51:11:655] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:655] [sx126x] netdev: set STATE_RX␊
[16:51:11:658] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:672] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:680] [sx126x] netdev: set STATE_TX␊
[16:51:11:733] [sx126x] netdev: SX126X_IRQ_TX_DONE␊
[16:51:11:733] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:733] [sx126x] netdev: set STATE_RX␊
[16:51:11:736] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:749] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:753] No ACK␊
submac receiver
[16:50:59:925] > [sx126x] netdev: SX126X_IRQ_PREAMBLE_DETECTED␊
[16:51:11:381] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:385] [sx126x] netdev: SX126X_IRQ_HEADER_VALID␊
[16:51:11:389] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:418] [sx126x] netdev: SX126X_IRQ_RX_DONE␊
[16:51:11:424] [sx[sx126x] netdev: set STATE_STANDBY␊
[16:51:11:429] [sx126x] netdev: set STATE_TX␊
[16:51:11:429] 126x] netdev: set STATE_TX␊
[16:51:11:429] NDB[sx126x] netdev: SX126X_IRQ_TX_DONE␊
[16:51:11:441] [nrf52840] TX ACK done.[sx126x] netdev: set STATE_STANDBY␊
[16:51:11:445] ␊
[16:51:11:445] [sx126x] netdev: read received data.␊
[16:51:11:445] DATA␊
[16:51:11:450] Dest. PAN: 0x0023, Dest. addr.: de:ee:68:50:08:4e:84:05␊
[16:51:11:455] Src. PAN: 0x0023, Src. addr.: a6:de:12:64:da:c5:b4:2b␊
[16:51:11:455] Security: 0, Frame pend.: 0, ACK req.: 1, PAN comp.: 1␊
[16:51:11:461] Version: 1, Seq.: 0␊
[16:51:11:468] 00000000 4C 6F 72 65 6D 20 69 70 73 75 6D 20 64 6F 6C 6F␊
[16:51:11:475] 00000010 72 20 73 69 74 20 61 6D 65 74 2C 20 63 6F 6E 73␊
[16:51:11:481] 00000020 65 63 74 65 74 75 72 20 61 64 69 70 69 73 63 69␊
[16:51:11:488] 00000030 6E 67 20 65 6C 69 74 2E 20 45 74 69 61 6D 20 6F␊
[16:51:11:494] 00000040 72 6E 61 72 65 6C 61 63 69 6E 69 61 20 6D 69 20␊
[16:51:11:505] txt (80 chars): Lorem ipsum dolor sit amet, consectetur adipiscing elit. Etiam ornarelacini␊
[16:51:11:505] a mi ␊
[16:51:11:505] RSSI: 205, LQI: 255␊
[16:51:11:505] ␊
[16:51:11:510] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:510] [sx126x] netdev: set STATE_RX␊
[16:51:11:534] [sx126x] netdev: SX126X_IRQ_PREAMBLE_DETECTED␊
[16:51:11:536] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:540] [sx126x] netdev: SX126X_IRQ_HEADER_VALID␊
[16:51:11:543] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:576] [sx126x] netdev: SX126X_IRQ_RX_DONE␊
[16:51:11:583] [sx126x] Addr filter failed or ACK filter on.␊
[16:51:11:583] [sx126x] netdev: set STATE_RX␊
[16:51:11:589] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:594] [sx126x] netdev: read received data.␊
[16:51:11:594] [sx126x] netdev: set STATE_RX␊
[16:51:11:600] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:608] [sx126x] netdev: SX126X_IRQ_PREAMBLE_DETECTED␊
[16:51:11:612] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:616] [sx126x] netdev: SX126X_IRQ_HEADER_VALID␊
[16:51:11:619] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:650] [sx126x] netdev: SX126X_IRQ_RX_DONE␊
[16:51:11:657] [sx126x] Addr filter failed or ACK filter on.␊
[16:51:11:657] [sx126x] netdev: set STATE_RX␊
[16:51:11:660] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:666] [sx126x] netdev: read received data.␊
[16:51:11:666] [sx126x] netdev: set STATE_RX␊
[16:51:11:669] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:685] [sx126x] netdev: SX126X_IRQ_PREAMBLE_DETECTED␊
[16:51:11:688] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:692] [sx126x] netdev: SX126X_IRQ_HEADER_VALID␊
[16:51:11:695] [sx126x] netdev: SX126X_IRQ_NONE␊
[16:51:11:727] [sx126x] netdev: SX126X_IRQ_RX_DONE␊
[16:51:11:734] [sx126x] Addr filter failed or ACK filter on.␊
[16:51:11:734] [sx126x] netdev: set STATE_RX␊
[16:51:11:738] [sx126x] netdev: set STATE_STANDBY␊
[16:51:11:743] [sx126x] netdev: read received data.␊
[16:51:11:743] [sx126x] netdev: set STATE_RX␊
ACK_TIMEOUT_US in submac.c sets in 13824 (SF7, BW500)
Hi @HoCoK
I’m interested in this. Do you think you could create a draft PR? Then I could test, with the lora-e5 board, and maybe help.
Thanks, David
Hi, @jdavid
I’ve created a draft pull request: github
If you’ll run it successfully, let me know, please
This is very interesting!
With PR #19172, I’ve successfully run the ieee802154_hal test using a LoRa-E5 Dev Board and a LoRa-E5 mini. However, I found that CAD was not working correctly when performing a stress test by letting both devices send 10 packets, starting roughly simultaneously. As you can see on the left, packets are colliding:
Then I found that the device is actually not waiting for SX126X_IRQ_CAD_DONE, but immediately goes to the transmit state. After I made some changes in the state machine, I get either “Medium busy”, or they start to transmit at exactly the same time (see the picture above on the right). I believe the latter is expected, because there is no CSMA/CA yet.
@HoCoK I see the PR is still in a draft version. Are you still working on this?
Hello @GUVWAF
Thanks for your message! I’m completely forgot about this PR because I had changed a job. But if it is interesting for someone, i’ll try to complete this.
That would be nice, but don’t feel obligated ![]()
I just opened a PR to your Fork with the changes I applied.
