when trying to use the hwtimer on the msb-430h I get this error during linking:
/home/milan/riot/RIOT/bin/cpu.a(hwtimer_cpu.o): In function `hwtimer_arch_init': /home/milan/riot/RIOT/cpu/msp430-common/hwtimer_cpu.c:74: undefined reference to `timerA_init' collect2: ld gab 1 als Ende-Status zur�ck make: *** [all] Fehler 1
void timerA_init(void) is defined in RIOT/cpu/msp430x16x/hwtimer_msp430.c, the build of the object was successfull.
milan@MilanDebian:~/riot/projects/hello-world$ ls -al ../../RIOT/bin/hwtimer* -rw-r--r-- 1 milan milan 752 Mai 15 10:15 ../../RIOT/bin/hwtimer_cpu.d -rw-r--r-- 1 milan milan 7676 Mai 15 10:15 ../../RIOT/bin/hwtimer_cpu.o -rw-r--r-- 1 milan milan 525 Mai 15 10:15 ../../RIOT/bin/hwtimer.d -rw-r--r-- 1 milan milan 712 Mai 15 10:15 ../../RIOT/bin/hwtimer_msp430.d -rw-r--r-- 1 milan milan 6464 Mai 15 10:15 ../../RIOT/bin/hwtimer_msp430.o -rw-r--r-- 1 milan milan 9600 Mai 15 10:15 ../../RIOT/bin/hwtimer.o
Is something missing like ar rcs $(RIOTBASE)/bin/hwtimer.a $(RIOTBASE)/bin/hwtimer*.o ? But In Makefile.modules I found:
# exclude hwtimer, because it is part of the kernel but the define is needed for auto_init export BASELIBS = $(shell echo $(BL)|sed 's/[^ ]*hwtimer.a//')
Full linker call is:
msp430-gcc /home/milan/riot/RIOT/bin/startup.o -o /home/milan/riot/projects/hello-world/bin/hello-world.elf -Wl,--start-group /home/milan/riot/RIOT/bin/posix.a /home/milan/riot/RIOT/bin/cc110x_ng.a /home/milan/riot/RIOT/bin/cc110x_spi.a /home/milan/riot/RIOT/bin/cpu.a /home/milan/riot/RIOT/bin/core.a /home/milan/riot/RIOT/bin/sys.a /home/milan/riot/RIOT/bin/transceiver.a /home/milan/riot/boards/msb-430h/bin/msb-430h_base.a /home/milan/riot/projects/hello-world/bin/hello-world.a -lm -Wl,--end-group -Wl,-Map=/home/milan/riot/projects/hello-world/bin/hello-world.map -mmcu=msp430f1612 -lgcc /home/milan/riot/RIOT/bin/startup.o
Although I am using the hello-world project here, it uses the hwtimer (the hello-world project on github does not). However same error also appears at other projects which use the hwtimer.
used gcc version is: msp430-gcc (GCC) 4.6.3 20120301 (mspgcc LTS 20120406 unpatched)
and used make version is: GNU Make 3.81
RIOT is the current git version milan@MilanDebian:~/riot/RIOT$ git show commit 336667a43ad81a147f060971a13edc2f0c34b268 Merge: d56081d 666c90f Author: Oliver Hahm <oleg@hobbykeller.org>
Can sombeody reproduce this, or has maybe even a solution?
Regards, Milan
