Dear RIOT users,
Hello. I am a new comer to RIOT OS. Recently I downloaded the latest version RIOT-2016.10 and tried to execute some examples.
At first I tried the “default” example. It is executed with no problem. Next, tried the “gnrc_networking” example. It caused a trouble as following,
First, created a tap interface,
sudo ip tuntap add tap0 mode tap user ${USER}
sudo ip link set tap0 up
Then, started the “gnrc_networking” by invoking as
PORT=tap0 make term
The following messages were displayed. The program was started but segmentation fault was caused
/home/user/Desktop/RIOT-2016.10/examples/gnrc_networking/bin/native/gnrc_networking.elf tap0
RIOT native interrupts/signals initialized.
LED_RED_OFF
LED_GREEN_ON
RIOT native board initialized.
RIOT native hardware initialization complete.
make: *** [term] Segmentation fault (core dumped)
Why is this problem occur?.
My development environment is
Ubuntu12.04 (is guest OS on host OS windows7)
In the gnrc_networking/README.md, “Ununtu14.04 comes with netcat IPv6 support pre-installed.” Is written. Is this problem caused by that netcat is not installed or unsuitable for Ubuntu12.04 ?.
If so, are there any solutions to execute “gnrc_networking” on Ubuntu12.04 ?.
My PC is Windows7. It may be impossible to upgrade to Ubuntu14.04.
Dicek Bear
Hello Dicek,
I couldn't reproduce the segfault on my system (Arch) with RIOT-2016.10.
Can you provide the core dump file? This way, we would at least know
where the crash occured. If no dump file is generated, then you can also
run `PORT=tap0 make debug` instead of `PORT=tap0 make term`. This
command will start your binary in gdb and you can run RIOT by typing
`run` in the gdb shell. In this mode, more information regarding the
segfault should be displayed.
BTW, Ubuntu12.04 is pretty old (: Do you have experience with
Vagrant[1]? There is a Vagrantfile in RIOT's root directory, which can
be used to jump-start a RIOT VM (Ubuntu16.04) with all necessary tools
pre-installed. You can find more information here [2].
[1] https://www.vagrantup.com/
[2] https://github.com/RIOT-OS/RIOT/blob/master/dist/tools/vagrant/README.md
Cenk Gündoğan
Dear Cenk,
Thank you for important information about my RIOT-2016.10 problem.
As you say, I found core dump file, but it was not generated.
Next step, I ran “PORT0=tap0 make debug” , and start RIOT program
by typing ‘run’ in the (gdb) shell. The following messages are displayed.
Starting program: /home/user/Desktop/RIOT-2016.10/examples/gnrc_networking/bin/native/gnrc_networking.elf tap0
LED_RED_OFF
LED_GREEN _ON
Program received signal SIGSEGV, Segmentation fault.
0x00000000 in ?? ()
In the “signup.h” file, ‘SIGSEGV’ means ‘Segmentation violation’. It is a
only information in the (gdb) shell display.
What does ‘0x00000000 in ?? ()’ mean ?.
Anyway it may be difficult to execute RIOT2016.10 on the Ubuntu 12.04.
I have not experienced Vagrant. If all necessary tools are pre-installed,
It it helpful for me. I try to install Vagrant.
Thank you,
Dicek Bear
Dear Oleg,
Thank you. I stop trying Ubuntu 12.04.
If some problems occur in Vagrant & Ubuntu 16.04, I will ask riot-users again.
Dicek Bear
Dear Cenk, Oleg and RIOT-users,
Thank you for your support.
Now I tried to install Virtual box version 5.1.12r112440 and vagrant_1.9.1 in Windows7 PC.
Installation of them was successed. Then I opened command prompt window and change
directory into RIOT root. At first I set a command to start Vagrant as following,
Vagrant up
Error message displayed,
Bringing machine ‘default’ up with ‘virtual box’ provider…
==> default: Box ‘RIOT/ubuntu1604’ could not be found. Attempting to find and install…
default: Box Provider: virtual box
default: Box version: >= 0
The box ’ RIOT/ubuntu1604’ could not be found or
could not be accessed in the remote catalog. If this is a private
box of HashiCorp’s Atlas, please verify you’re logged in via
‘vagrant login’. Also, please double-check the name. The expanded
URL and error message are shown below:
URL: [“https://atlas.hashicorp.com/RIOT/ubuntu1604”]
Error: Failed to connect atlas.hashicorp.com port 443: Timed out
The displayed URL and port number 443 directs a address of “RIOT/ubuntu1604 box file”,
doesn’t it ?. In my PC environment, it is impossible to connect Internet, because company
security does not allow access Internet.
Can we download ‘RIOT/ubuntu1604 box file’ manually ?. I tried to access the URL, but
It was necessary to input username and password.
Are there any methods to install and use Vagrant(Ubuntu1604) with Internet disconnected
environment ?.
Dicek Bear.
