I tried to compile it for stm32f4discovery. Had to make changes in a couple of Makefiles to make it work. Is there a Wiki page or README that explains how to compile RIOT for a third-party board?
Thanks, Mark
Thanks, Mark
Hi Mark, The documentation for several boards is available in the Github-Wiki [1]. For the discovery board the doc can be found here: [2] But basicly you have to set the environment variables RIOTBOARD and RIOTCPU to your lo al thirdparty_board and thirdparty_cpu repository, respectively, before calling make. So what you want is
RIOTBOARD= RIOTCPU= BOARD=stm32f4discovery make
Have fun, Martine
[1] https://github.com/RIOT-OS/RIOT/wiki/RIOT-Platforms [2] https://github.com/RIOT-OS/RIOT/wiki/Board:-STM32F4discovery
Hello Martine,
Thanks for the links. I've posted here the errors that I encountered and how I fixed it. I know its lengthy. Sorry I didn't have an option. :-/
Here is my folder structure. ~/RIOT/   - RIOT-OS   - thirdparty_cpu   - thirdparty_boards
Commit information: mark@beast:~/devel/RIOT$ for i in `ls`;do cd $i;echo $i;git describe;cd ..;done RIOT-OS 2014.01-745-g8526184 thirdparty_boards 2013.08-49-g894b006 thirdparty_cpu 2013.08-68-g24f7ca3
Hi Mark,
Hello Martine,
Any updates on this?
~Mark
Hi Mark, Kinda, turns out the stm32f4discovery port is not very well maintained. But there is an “official” (as in “not in a thirdparty repository”) port in the making, that is not needing any extra (license-incompatible) library. Look for a pull request by @haukepetersen in the next few days in our main repository.
Kind regards, Martine
Hi again, it is actually already there: https://github.com/RIOT-OS/RIOT/pull/1191.
Happy testing, Martine
Hello Martine,
Hi Mark, Kinda, turns out the stm32f4discovery port is not very well maintained. But there is an "official" (as in "not in a thirdparty repository") port in the making, that is not needing any extra (license-incompatible) library. Look for a pull request by @haukepetersen in the next few days in our main repository.
Thanks. I'll pull that 1191 req and do a test.
BTW, I'd like to know what sort of license incompatibility issues demanded a separate thirdparty_xxx repos. (Any mailing list discussions would be fine)
Also, Is the CMSIS library license compatible?
~Mark
