Hello guys,
I am currently trying to make three nodes communicate using RPL and UDP in native. One node is the host and send a message. The second node is a router, receive the message and forward to the third node. The third node is the root.
I don’t want the host to be able to communicate directly to the root node.
I read the example rpl_udp to help me, but :
- in this example the host nodes don’t use RPL, so how can they send message ?
- how can I indicate in my network that the host cannot send a message directly to the root and has to send it to the router first.
If someone can help me about network configuration or RPL/UDP implementation.
Thanks,
Caroline QUEVA Research Engineer at CEA-LIST DRT/LIST/DACLE/LIALP Laboratoire Infrastructures et Ateliers pour le Logiciel sur Puces
Commissariat à l’énergie atomique et aux énergies alternatives MINATEC Campus | 17 rue des Martyrs | 38054 Grenoble Cedex 9
