Dear developers
I am new to RIOT, i have to build a hardware IoT system and do intrusion detection for detecting ddos attack using machine learning and run that on build hardware.
Please advice me i am thinking about zolertia z1 mote for building IoT network will i be able to do my work on that.
If you have any other hardware choice please recommend to me.
Thanks &Regards
Monika Roopak
Hi Monika,
and welcome to RIOT! I would advice against using z1 nodes because they
have really limited memory which won't allow you any in spare when using
network modules. I would recommend:
Atmel samr21-xpro
https://github.com/RIOT-OS/RIOT/wiki/Board%3A-SAMR21-xpro
Phytec phyWAVE
https://github.com/RIOT-OS/RIOT/wiki/Board%3A-Phytec-phyWAVE-KW22
Remote Revision B (relatively new in RIOT)
https://github.com/Zolertia/Resources/wiki/RE-Mote
Also consider the fit iot-lab which consists of custom "iotlab-m3" nodes
with default components on it:
https://www.iot-lab.info/
Best regards
Peter
Yeah! That’s good try to use atsamr21…
