I followed the quick start in documentation. https://doc.riot-os.org/index.html#the-quickest-start I am running this on ubuntu 18.04.
after cd examples/default/ make all It gives errors: Building application “default” for “native” with MCU “native”.
gcc: error: unrecognized command line option ‘-Wformat-overflow’; did you mean ‘-Wstrict-overflow’?
gcc: error: unrecognized command line option ‘-Wformat-truncation’; did you mean ‘-Wline-truncation’?
/home/chris/riot_project/RIOT/Makefile.base:107: recipe for target '/home/chris/riot_project/RIOT/examples/default/bin/native/application_default/main.o' failed
make[1]: *** [/home/chris/riot_project/RIOT/examples/default/bin/native/application_default/main.o] Error 1
/home/chris/riot_project/RIOT/examples/default/../../Makefile.include:618: recipe for target 'application_default.module' failed
make: *** [application_default.module] Error 2
my gcc version is: gcc -v Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/6/lto-wrapper Target: x86_64-linux-gnu Configured with: …/src/configure -v --with-pkgversion=‘Ubuntu 6.5.0-2ubuntu1~18.04’ --with-bugurl=file:///usr/share/doc/gcc-6/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++ --prefix=/usr --with-as=/usr/bin/x86_64-linux-gnu-as --with-ld=/usr/bin/x86_64-linux-gnu-ld --program-suffix=-6 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --with-sysroot=/ --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-libmpx --enable-plugin --enable-default-pie --with-system-zlib --with-target-system-zlib --enable-objc-gc=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu –target=x86_64-linux-gnu Thread model: posix gcc version 6.5.0 20181026 (Ubuntu 6.5.0-2ubuntu1~18.04)
any idea? Thanks
