Hi Martine,
thx for the input
> Are you planning to only consider stateless compression (Prefix is assumed link-local) or also stateful compression (Prefix is determined by a 4-bit context ID [1] ...
I plan to make it more generic, e.g. allow for providing even proprietary "solutions" for FIB table entry compression. LOWPAN_IPHC provides wonderful mechanisms to save bytes in transmissions, but there are probably (most likely) more possibilities to save bytes on the individual nodes RAM when maintaining a FIB table.
Eventually the FIB will "resolve" the applied compression to provide the type required by a `get_next_hop()` request.
>... we might want to consider to put those information into the same data structure (so the later of my 2 suggestions above would be)
Indeed, that would by great. That's the reason I want to outsource the "Generic address" from the FIB table entry. These blobs can be shared among processes, e.g. FIB, routing protocol and ND.
Liftime invalidation and such is controlled by the individual process.
For instance, an expired FIB table entry would mark its internal structure as invalid and decrease the usecount of the "Generic address".
> Also: have you considered Mesh-under routing [5]? (Do we have to consider this here I wonder myself? We don't have support for it anyways, so far.) [6] states some requirements for this.
No, I only considered to "play" at the network layer level for now. But I will have a look.
Best Regards,
Martin
I finally came to it to read your suggestions, too. Regarding the fact that you keep 6LoWPAN header compression in mind, too: Are you planning to only consider stateless compression (Prefix is assumed link-local) or also stateful compression (Prefix is determined by a 4-bit context ID [1], disseminated through the PAN via the context identifier option in RS [2]). Since Neighbor Cache [3], Prefix Information [4], Forwarding information, and Context Information are all very related, and we may want to save memory, we might want to consider to put those information into the same data structure (so the later of my 2 suggestions above would be). Keep in mind though, that both Prefix Information Base and Context information Base have their own lifecycles (see regarding RFCs).
Hope this was more helpful, than confusing ;-).
Martine
[1] https://tools.ietf.org/html/rfc6282#section-3.1.2
[2] https://tools.ietf.org/html/rfc6775#section-4.2
[3] http://tools.ietf.org/html/rfc4861#section-5.1
[4] https://tools.ietf.org/html/rfc4861#section-4.6.2
[5] https://tools.ietf.org/html/rfc4944#section-11
[6] http://tools.ietf.org/html/rfc6606
Attached Message Part (135 Bytes)
