I’m using a nucleo board using an STM32WL55JC1 which is based on a dual-core architecture.
I want my application to be as low-power as possible, at the moment i’m reaching 1.6 mA (by switching the main core to stop mode). I was wondering how the multi-core architecture are handled in riot-os.
Can i use the second CPU?
Is this second CPU clocked by default or do i need to “turn it off” by a mean or another to decrease power consumption?
currently there is no support for a second CPU or core in RIOT at all for any platform.
I’m not sure if the second core is explicitly disabled, but it certainly is not enabled by any code. That would be something to look up in the STM32WL55 reference manual I guess and compare it with the platform specific code in RIOT.
In theory you can use the second cores, but there are no provisions in RIOT to help you with that. That means you’ll have to compile and load a program separately and implement a means of communication between the cores.
The STM32WL55 datasheet has some information about power usage of the core(s) and different components that will give you an idea whether or not the power consumption you’re currently seeing is within what’s to be expected or not. The power consumption mainly depends on the clock frequency, which AFAIR is set to the maximum in RIOT. You can decrease the clock frequency to save some power.
There are some pre-configured default frequencies, but other than that you’ll have to set the PLL values manually, which can be a bit tricky. The easiest approach is to define the clock tree with STM32CubeMX and then read off the values from there and populate the respective configuration defines.
For reference you can take a look at these files:
I will read the datasheet, and see if i can manually configure register (is there any function to read/write register in stm32 or do i use just a pointer to the register location).
