A quick question, what functions should I use to convert between a char * and int in RIOT?
/Adeel
/Adeel
Well, in c any Pointer is an integer. If you want the plain numeric value, you can just cast the pointer to int. There is no conversion function
The char * is a string here. Basically what I want is the equivalent of sprintf().
/Adeel
Ah okay. You are looking for atoi()
atoi() converts from a string to an int. I want to convert an int to a string.
/Adeel
You can do that with snprintf an its Format specifires
Try
sprintf(a_string, "%d",the_int);
Marc
Hi, sprintf (and it’s siblings) should be avoided in production code though, since in newlib these functions are quite large. I’m not sure if this exist on all platforms, but there is also atoi()'s counterpart itoa().
Cheers, Martine
(( Meanwhile the original question was clarified. ))
Still I wanted to say that, in C99 there are specific types to convert a pointer to an integer type. Don't just cast a pointer to an int or a long. It is not portable.
