I am trying to do multi-hop routing with the Fit Iot Lab testbed,using the
m3 nodes. However, the nodes are very close and they can communicate
directly. Do you know if there is a way to change the transmission power
of the AT86RF231 module ? I have looked in the boards/iotlab-m3 folder,
and in the drivers/at86rf2xx folder, but I don't know exactly what to
change.
Thank you,
Eliot
Hi Elliot,
if you are running a shell example such as gnrc_networking you can use
the following command:
ifconfig 7 set power -3
where 7 is the interface ID and -3 is the power (in dBm). If you want to
set this in your application code you could use the netapi, e.g.:
uint8_t power = 100;
ret = gnrc_netapi_set(ifs[0], NETOPT_TX_POWER, 0, &power, sizeof(power));
Cheers
Peter
Hi Eliot,
from experience I can say that modifying the tx power isn't cutting it
most of the times. What I would recommend is to choose nodes that are
far apart – you can use the Grenoble site for that. If that doesn't work
out for you, you can also use the l2filter [1] module of RIOT. With
USEMODULE += l2filter_blacklist or
USEMODULE += l2filter_whitelist
you can establish the default policy. Then you can use the `ifconfig`
shell command to blacklist or whitelist specific node link-layer
addresses.
Now that I look at this feature, I see there's only a very minimalistic
documentation on how to use it and no examples/tests for the l2filter
(yet). But you can have a look at the usage within the `ifconfig` shell
command [2] if you plan to control the white-/blacklist
programmatically.
Cenk
[1] http://doc.riot-os.org/l2filter_8h.html
[2] https://github.com/RIOT-OS/RIOT/blob/master/sys/shell/commands/sc_gnrc_netif.c#L926
Thank you for the answers. The devices was too close on the Lille site,
and even with the reduction the transmission power, they would still be
able to communicate with each other.
I managed to do multi-hop routing using the Lille site with the l2filter.
I chose this site because of the grid layout it can provide with the
m3-node.
Thank you for the help.
Eliot Chauvineau
