i am a developer from China, and i read that CCN-lite is ported on RIOT, and many cpu arch and board supported by RIOT.
So i wanna ask which board platform has a good support by RIOT? and can run CCN-lite stack on RIOT? as far as i realize, i guess Arduino Dueis a good one?
And i read a paper which using MSBA2 board to run CCN-lite on RIOT, but there are few info. about this borad on internet, i guess this board is designed by Freie Universitat Berlin?
Thanks in advance
Best Regards
Sichen Zhao
Hi Sichen!
I have experience in using CCN-lite with the boards:
samr21-xpro [1] and
phyNode [2]
and it works quite well there. I've never tried it with an MSBA2.
In general however, every board with enough memory (say, >= 32kB RAM)
should be fine. If you decide for a board without a (IEEE 802.15.4)
transceiver, then you can also attach an SPI-based transceiver module
like an openlabs [3] or an mrf24j40 [4]. So an Arduino Due attached with
one of these transceivers might probably work. I have no experience with
that board, though.
Cenk
[1] https://github.com/RIOT-OS/RIOT/wiki/Board%3A-SAMR21-xpro
[2] https://github.com/RIOT-OS/RIOT/wiki/Board%3A-Phytec-phyWAVE-KW22
[3] http://openlabs.co/OSHW/Raspberry-Pi-802.15.4-radio
[4] http://www.microchip.com/wwwproducts/en/en027752
