Hi everyone, is it okay to pull latest source code of RIOT now ? After doing this, I can’t run or debug my iot-lab_M3 app anymore. Then I tried to build ipc_pingpong example, it worked fine with native but not with iot-lab_M3. ipc_pingpong example in my old source code (I forked it about one month ago) worked just fine with iot-lab_M3.
One thing strange with the new code is that when I apply -Wl,-gc-sections (to remove unused sections) to LINKFLAGS (in thirdparty_boards/iot-lab_M3/Makefile.include) when building ipc_pingpong (in new source code), I got this:
0 0 65536 65536 10000 /home/dangnhat/RIOT-working/newRIOT/RIOT/examples/ipc_pingpong/bin/iot-lab_M3/ipc_pingpong.elf
It doesn’t happen with my old code.
Thanks in advance.
DangNhat.
* Phạm Hữu Đăng Nhật
* StudentID: 51002279
* Class: MT10KTTN
* Ho Chi Minh University of Technology
* Mobile: 0164.968.2716
Hi DangNhat,
In general, our master should always work. As our CI setup is not complete yet, it is not possible to assert this though. Therefore it is possible that there is a bug in master. It is also possible that some change in master requires a change in the third party code.
You can use ‘git bisect’ to find out if there is a problem and what it is =)
Cheers, Ludwig
Hi Ludwig,
I haven’t ‘git bisect’ yet but I think I found the bug: we are missing UNDEF += $(BINDIR)cpu/startup.o in the thirdparty_boards/iot-lab_M3/Makefile.include
This is what I have found: in the final image, we don’t have ISR table and startup code at the beginning address for flash mem (0x08000000). This can be seen in .map file
.isr_vector 0x08000000 0x0
0x08000000 . = ALIGN (0x4)
*(.isr_vector)
it should be
*(.isr_vector)
.isr_vector 0x08000000 0x1e4 /home/dangnhat/RIOT-working/RIOT/examples/ipc_pingpong/bin/iot-lab_M3/startup.o
0x08000000 g_pfnVectors
0x080001e4
Without ISR table, the application definitely can not run. So I took a look at command line for the linker and found that it didn’t link startup.o, which should be defined in UNDEF variable. I have also taken a look at Makefile.include (s) of some other boards in RIOT repo. They all have UNDEF += $(BINDIR)cpu/startup.o .
I will test this a little more before make a PR on github but at least, now I can run and debug my app again .
Beside, one thing I need to be confirmed: UNDEF += $(BINDIR)cpu/startup.o is intended to be placed in Makefile.include of every boards instead of in RIOT/Makefile.module (like in my old code) ?
DangNhat.
* Class: MT10KTTN
Thomas put some effort in the support, his results are here:
https://github.com/RIOT-OS/RIOT/pull/1056
I think your problem should be fixed with this pull request.
The problem was a change in the make system which was not properly done in the thirdparty repo.
Best
Christian
actually the fix for subdirectories in $(BINDIR) is in this PR [1].
Though I didn't get zero sized code binaries it seems to fix our boths
problems. DangNhat, let us know if this PR solves it for you too.
Best,
Thomas
[1] https://github.com/RIOT-OS/thirdparty_boards/pull/24
Though I didn’t get zero sized code binaries it seems to fix our boths
A big yes, this PR will solve my problem. I got zero sized binaries because I have applied -Wl,-gc-sections to LINKFLAGS. (without ISRs in startup.o all the code will be unused)
Thank you,
DangNhat.
