I'm using two SAMR21, one with BR (on A) and the other (on B) with
gnrc_networking example.
I'm on April release.
Switch on A (border router) then switch on B, I'm able to send UDP
message from Linux to 2001:db8 address of B.
If I try to send lot of data (every 100ms), it works for a while and
then B does not receive message anymore. After I see it failed, I
stopped the loop sending UDP message, I checked on BR and 2001:db8
address of B was not here anymore. I can ping B with fe80:: address on
iface 6 but can't with 2001:db8.
Why or how can a node be removed from ncache? Why the node does not
automatically reconnect with BR?
As the implementer of the neighbor discovery I can say this: because
the neighbor discovery is sh** ;-). It was written in a haste and has
a lot of design flaws. I'm working on a replacement (see
https://github.com/RIOT-OS/RIOT/issues/5704, happy to hear your
thoughts ;-)), but sadly I did not find some time to put heavy
implementation efforts into this yet (hopefully in autumn though, so
we have something for the October release, fingers crossed).
(sorry, hit the send button for the previous mail accidentally to early)
Thanks Martine,
The issue you mentioned seems to be different.
Okay, could you report that issue to the tracker then please so I
don't lose track of it.
Did you see the neighbor discovery implementation of OpenThread? How
your new implementation will be able to dicuss with OpenThread
implementation?
Is it different from RFC 4861 [1] or RFC 6775? If not, then yes it
will be able out of the box. If it is different, a port for that
should be simple in that the whole routing/address resolution
mechanism will be quite interchangeable with the API proposed in #5704
[3] (but since my know-how about OT is very limited, that
implementation might need to come from a different person ;-)).
Martine, Kaspar, AFAIK, OpenThread follow RFC standard and they added
their part on top of it, but I don't know if it will be fully
compatible.
OpenThread doesn't use IPv6 neighbour discovery, they use a forked MLE
protocol which is maybe ~80% of that what IETF MLE is. They use MLE for
neighbour discovery, means filling neighbour entries with that. Also I
saw that they broadcast a stateful compression CID over MLE. The rest I
currently try to detect by using the force, ehm source.
Also you cannot be sure that OpenThread really follow any IETF standard
and do they own forks. Please see my question [0].
So OpenThread 6LoWPAN is _maybe_ not IETF 6LoWPAN.
