Thanks Martine, I will try tomorrow
Ah the problem seems to be that for some reason Linux elects a link-local address for the ping, which is of course due to the fact, that there is no global address assigned to the interface and that the hop limit seems to be set to short (it is 1). So I did the following
sudo ip route add ff1e::/16 dev tap0 table local # add routing entry for ff1e::1 sudo ip addr add affe::dc53:7dff:fe99:516e/64 dev tap0 # add global unicast address for tap0 ping6 -t 2 ff1e::1 # ping with hop limit 2
I did try but ping6 does not receive anything Did you do any more set up? What is this address dc53:7dff:fe99:516e?
#ip -6 route list table local ... ff1e::/16 dev tap0 metric 1024 ...
#ifconfig tap0 tap0 Link encap:Ethernet HWaddr 26:C5:07:2F:43:E0 inet6 addr: fe80::24c5:7ff:fe2f:43e0/64 Scope:Link inet6 addr: fe80::1/64 Scope:Link inet6 addr: affe::dc53:7dff:fe99:516e/64 Scope:Global UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:58 errors:0 dropped:0 overruns:0 frame:0 TX packets:326 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:500 RX bytes:4706 (4.5 KiB) TX bytes:29442 (28.7 KiB)
