i’m wondering how i could define an auto-configuration for the 802.15.4 interface (on boot) for my “microcoap_server” example.
At now i’m using this configuration (set up by shell)
// Channel
ifconfig 6 set channel 12
// Global IPv6
ifconfig 6 add my_address
// Route
fibroute 6 add :: via
I would like to execute these commands automatically.
Thanks all,
Hi Alessandro,
have you assigned a global unicast address to the 6LoWPAN interface on
the Raspberry Pi and started the radvd demon normally it should (but
maybe Alex Aring can confirm that) it should than start to provide the
prefix in the LoWPAN via stateless address auto-configuration. Ideally
the default route should be set in the same step (though it would not
be shown in the FIB, since this is done via the neighbor discovery and
its neighbor cache). Alternatively use another 802.15.4 node with
examples/gnrc_border_router as the border router, there it should
definitely work, especially if you activate RPL (`rpl init <if>` on
both node and border router and `rpl root <GUA of 6LoWPAN interface>`
on router).
Martine
