I am getting started with the Arduino Due board and I can't do any input instructions. The Hello_World project works well, but if I want to use some getchar() instructions(as in the test_shell project) nothing happens. I connected my UART device to TX0 and RX0 pins and it seems like only the TX0 pin works...
Actually I had already tried this because I work with Peter Kietzmann and he told me to do this (You helped him for the same problem on the stm32f4discovery if I am not wrong).
However "getchar()" seems not to end, I tried to print something after this instruction. I don't know if getchar() waits for an EOF that never comes or if my RX pin just does not send anything.
May be I am using the wrong tools ? As I did for stm32f4discovery, I am using pyterm to launch my "/dev/ttyUSBxxx" which is my UART device. Then I only connect it to the TX0, RX0 and GND pins.
Can you describe me what you did to make it works ? Because I have been looking for some tutorials for Arduino Due but I do not find anything very interesting...
for the arduino-due you actually do not need to connect any external
uart-usb adapter, as the arduino already has one included. For the
default project, you should be able to do the following:
cd examples/default
make -B clean all
make flash
make term
This open a connection to the board and you should be able to talk to
the shell (sending to the board only works with my patch.. -> see PR below).
