Riot lags some way to declare, that a function parameter
is unused. This commit adds a file called “unused.h”,
which defines some nice macros.
http://stackoverflow.com/questions/3599160/unused-parameter-warnings-in-c-code
this commit fixes #62 (the discussion wasn’t finally over in this issue)
Sorry, but I don’t quite see the advantage in using UNUSED(variable)
compared to the standards compliant (void) variable
Let me elaborate further why I’d prefer (void) var
Using type UNUSED(var)
in the parameters does tell anything why it is unused, it simply hides a warning. You could accomplish that by using the -w
parameter …
But (void) var
can be used in the appropriate #IF
branch, and/or you can assign a proper comment to it:
(void) var; /* var is unused because of reason */
Also, (void) var; works without any macro magic. I *hate* everything written in all-capitals within function blocks and try to avoid it like the pest.
ok, I see. You two prefer an other way
@Kijewski make a pull request and I’ am totally with you in merging your code!
after having fixed this class of problems, there’s just one single warning in riot (-Wall and -Wextra enabled, gcc and clang), so we are on a good way to have a warning free system!
Guys, this is AWESOME. If it's true for all supported platforms, let's add -Werror to CFLAGS, make a nice headline and boast about it in our features list!
+1 for committing (void) stuff.
current “master”+“unused fixes”: native and msba2 are warning-free. msb-430h has some warnings.
I agree with @Kijewski the mysterious @RIOT-notifier ;-). So, I guess we can close this one.
