I would like to link libexample.a in my RIOT example, what should I add in the Makefile?
Thanks,
Thanks,
I tried to use APPDEPS += libexample.a Does not work
Hey,
Hi Kaspar!
BASELIBS += libexample.a makes it work!
Hi Baptiste!
Weird, Oleg, did you try to use the library? Could you include .h file which are inside .a library and use some functions. It was able to find the library .a but couldn't link with function inside the library
Baptiste,
the libexample.a just contains one .o file with one function (`int my_add(int a, int b);`, see https://github.com/OlegHahm/miniature-dangerzone/blob/master/static_linked/main.c#L3). This function gets linked and successfully called if you build the application.
